mise à jour firmare attendue le 26/7
Herve5
Depuis le 24 fév 2016
France, sud-est
annonce en Anglais, sur le forum Leica :
http://www.l-camera-forum.com/topic/262 ... 20-on-726/
Liste des mises à jour escomptées:
1. DNG only mode added
DNG is now available as a separate mode (besides JPG and DNG+JPG).
2. EVF extended mode implemented
The user can switch to the monitor image for menu control and image review immediately by pressing the Menu or Play button.
3. Extended low shutter speed range
Shutter speed up to 120s can be set.
4. User Profile menu item directly accessible
User Profile has been added to the modes selectable by the FN button. This facilitates quick and easy access to any specific mode stored in one of the user profiles, e.g. Monochrome.
5. Level Gauge display changed
The Level Gauge display remains visible when the Shutter button is pressed.
6. Size of 1 Point AF metering area selectable (Small / Standard / Large)
By pressing the Delete button in the 1 Point AF mode the size of the AF field can be changed/selected by using the thumbwheel.
7. 1 Point AF movement in digital zoom mode limited
When using the focal lengths 35mm and 50mm available in Digital Zoom mode, the 1 Point AF metering area movement is limited to within the respective frames.
8. Improved Face Detection AF mode function
In Face Detection mode the camera switches automatically to Multipoint AF if no face can be detected.
9. Additional information display screen added
Fourth info screen has been added with the option to display the lower bar separately.
10. Image playback touch zoom function changed
Double-tapping calls up the maximum enlargement/reduces back to original size.
11. Long exposure / Noise reduction countdown added
12. Three modes available for the thumbwheel (Off / AUTO / Exp. Comp.)
13. Mode Lock of the video button implemented
The video button can be deactivated if desired.
14. WIFI Password setting changed
All characters entered for the password remain visible during the process.
15. Flash unit compatibility extended
The Leica flash units SF 40 and SF 64 are supported.
Revilo
Depuis le 16 mai 2013
Paris 15eme (75015)
Bonne nouvelle !
Alain 91
Depuis le 2 fév 2009
Boulogne-Billancourt
Pour moi le 3 et 11 m'intéressent beaucoup car faire, par exemple, des photos de la voie lactée avec la limitation actuelle de 4s à 6400 ISO rend l'opération quasi impossible.
espafran
Depuis le 13 mai 2015
Pas mal de choses quand même et non des moindres !! Le passage à 120 secondes pour la pose longue est pour moi une excellente nouvelle que j'attendais et qui rend le Q encore mieux adapté à mes pratiques.
Reste maintenant à l'équiper de filtre ND !!!
mikewest
Depuis le 13 nov 2012
Theux
J'ai utilisé le flash sf40 sur le leica q hier lors d'un mariage...
J'ai été particulièrement déçu de son comportement en ttl, et en mode priorité ouverture sur l'apn... (Comportement très différent de mon flash canon 580Ex sur 5d2). J'ai finalement du utiliser le flash en manuel ... Est-ce lié au firmware non finalisé pour le leica q avec ce flash, ou les flash leica sont moins fiables en ttl?
Herve5
France, sud-est
Le SF40 n'est pas encore compatible du Leica Q, ce qu'on entend ici c'est que la future mise à jour du firmware va bientôt le supporter (en TTL notamment).
C'est donc normal que tu n'aies pu t'en servir qu'en manuel hier...
Solal
Depuis le 12 fév 2005
Puisque vous parlez des flashs avec le Q, j'ai acheté d'occasion un SF58 il y a peu de temps.
Pensez-vous qu'il sera supporté si le 40 et le 64 le sont maintenant officiellement?
Nicci78
Depuis le 22 mai 2014
IdF
Le Q est sûrement compatible avec le 58 qui est ancien et basé sur les Metz. Cette mise à jour ne concerne que les nouveaux flash sf40 et 64 basé sur les Nissin. Mais c'est bizarre que cette mise à jour ne soit pas arrivée avant.
DNG ONLY : LEICA RICOH PENTAX
Herve5
France, sud-est
Tu peux peut-être trouver un gars dans les Yvelines, ou sur Paris, qui ferait l'essai? (je ne suis pas du tout en région parisienne hélas, bien que j'aie l'intention d'y passer le dernier WE d'Août...)
JCR28
Depuis le 9 jan 2010
Chartres/Dreux
Vivement demain....
viewtopic.php?f=94&t=70386&start=930
John Stuart Mill
Herve5
France, sud-est
JCR28 a écrit :
Vivement demain....
Il n'y a rien aujourd'hui pour l'instant.
Pour rappel, si la chose n'est pas juste une rumeur, le fichier de mise à jour devrait apparaître sur cette page , en bas...
H.
JCR28
Chartres/Dreux
Ce nouveau firmware est confirmé par des "beta testeurs" ici sur Summilux "voxen" et sur un autre forum......
rendez vous sur cette page. https://fr.leica-camera.com/Service-Sup ... uage=68390
John Stuart Mill
JCR28
Chartres/Dreux
Le 2.0 est en ligne. https://fr.leica-camera.com/Service-Sup ... uage=68390
John Stuart Mill
ipfixe
Depuis le 20 mai 2016
AJACCIO
Bonne nouvelle pour les amateurs de poses longues comme moi et sympa pour le fichier DNG solo, bonne après-midi. ;)
" Il n'y a pas de lumière sans ombre " Louis Aragon
albi
Depuis le 24 juin 2016
paris
DNG als alleiniges Format hinzugefügt 2. EVF Erweitert-Betriebsart hinzugefügt 3. Verschlusszeiten bis zu 120s jetzt verfügbar 4. Menü-Unterpunkt Benutzerprofil jetzt direkt aufrufbar 5. Veränderung der Wasserwaage-Anzeige 6. Die Größe des 1 Punkt -Messfeldes jetzt wählbar 7. Verstellbereich des 1 Punkt-Messfeldes bei Verwendung der ‘Digitalzoom‘-Brennweiten begrenzt 8. Verbesserte Funktion der AF-Betriebsart Gesichtserkennung 9. Eine weitere Anzeige-Variante hinzugefügt 10. Berührungsgesteurte Vergrößerung bei der Wiedergabe verändert 11. Anzeige der verbleibenden Zeit bei Langzeit-Belichtungen / Geräuschverringerung 12. Menüpunkt Daumenrad hinzugefügt 13. Menüpunkt Betriebsart Foto/Video festsetzen hinzugefügt 14. Veränderung der WIFI-Passwort-Einstellung 15. Erweiterung der Blitzgeräte-Kompatibilität
heureusement je parle deutsch,
j'ai installé la mise à jour
formatez carte
puis pressez le bouton video
et en même temps allumez la camera
dites: yes
Retourner vers Leica Q
