| Curly |
Spécialiste Messages : 1980Depuis le 19 sep 2007 Paris |
Il est un fil sur rangefinder forum, là, http://www.rangefinderforum.com/forums/ ... adid=74565 qui dit que cosina sortirai bientôt un nokton 50 f1.1
ça me plaît. et pour ceux qu'aiment pas les rumeurs et qui s'apprêtent à râler: pourquoi avez vous cliqués sur mon fil? pour les autres: ce serait bien, hein? Allez, je retourne bosser. |
| chrisk |
Vieux briscard Messages : 6225Depuis le 16 mars 2007 Mulhouse |
Un compatible de plus !
Wait and see... "Il n'y a pas de bons ou de mauvais sujets, il n'y a que la qualité du regard qui se pose sur eux."
J.L SIEFF |
| Laurent A |
Moi, ça me plairait bien Même s'il n'ouvre pas autant, je suis convaincu que Voigt va rapidement renouveler son Nokton 50 et le passer en monture M... |
| Curly |
tom abrahamson confirme :
"Indeed, there is a 50mm f1.1 from Cosina. I did shoot with it in March when we were in japan. Of course, i had to keep quiet about it, which is not easy! It is a very sweet lens, slightly smaller than an older style Noctilux, 58mm filter thread. Weight seemed to be similar, or slightly lighter. The prototype looked a bit like a Nokton 50f1.5 on steroids. Similar knurling on the focus and it "sat" well in the hand when on the camera. There were two versions of the hood. One was a smallish, thread mount one, slightly flared (minimum intrusion into the finder of the M2 and ZM) and the other one was a larger diameter one with a clamp-on screw. Image quality was very good. For obvious reasons I shot most everything at f1.1 or there-abouts. The corner fall off is less than on the Noctilux f1.0- looks to be around 1,0-1.5 stops. Less of peering through a tunnel as the Noctilux tended to create. Sharpness at f1.1 is very good - I did not do "resolution" tests - but looking at the negatives - I would have no problem blowing them up to 11x14 or 16x20 without having the lens being the limiting factor. I did shoot most of the pictures with Acros 100 and developed them in Beutler. This is a combination that takes "no prisoners" in terms of sharpness and contrast. The price seems to be set at around $1100 - but that might depend on exchange rate too. I will post some shots from it later today. What I liked is the fact that a/ a bit more compact than the Noctilux and b/ apart from being very good at f1.1 - the quality when stopped down held up and it is nice and sharp throughout the whole f-stop range. This means to me that it could do duty as a "standard" 50mm without loosing image quality in bright light and on the "dark" side." que l'on peut traduire rapidement par "oui, c'est vrai, j'ai essayé un prototype au japon : un peu plus petit que le Noctilux (l'ancien), 58mm pour le filtre, un poil plus léger que le Nocti. Comme un Nokton 50 au stéroide, tenant bien dans la main. 2 versions de pare soleil, etc. le plus important : très bonne qualité d'images - il n'a pas fait de test de resolution mais il pense pouvoir faire de 11x14 pouces ou 16x20 (40x50cm) sans problème a PO (il a shooté avec de l'acros 100, donc bonne idée du piqué) - il ajoute que le piqué semble bon à toutes les ouvertures, donc qu'on puisse l'utiliser comme cailloux de tous les jours ; le prix semblerait devoir être de 1100 dollars. en un mot: génial. |
| Abdoulaye L. |
Spécialiste Messages : 2077Depuis le 13 jan 2007 Strasbourg |
gé-nial.
Photos ici : http://www.flickr.com/search/?q=Voigtlander%20Nokton%2050mm%20f1.1&w=36506481%40N00 |
| Curly |
on peut même plus s'enthousiasmer d'une joie enfantine devant un prodige à prix cassé sans que quelqu'un se moque. c'est dur. |
| manukiev4 |
Régulier Messages : 296Depuis le 4 oct 2005 dijon |
Ca à l'air prometteur, question prix aux environs de 1000 euros c'est tenable si on le compare à un noctilux. Ca commence par : "Jak sie pan?"; et ça fini par : "Do dna".
Plus la visée est claire, plus le regard est lucide. |
| chrisk |
Ce qui parait curieux, c'est qu'on en parle à peine à l'heure l'actuelle, alors que les post sur Flickr
sont datés du 1 au 8 avril. "Il n'y a pas de bons ou de mauvais sujets, il n'y a que la qualité du regard qui se pose sur eux."
J.L SIEFF |
| Abdoulaye L. |
chrisk a écrit : Ce qui parait curieux, c'est qu'on en parle à peine à l'heure l'actuelle, alors que les post sur Flickrsont datés du 1 au 8 avril. Ils n'étaient pas encore estampillés! |
| Abdoulaye L. |
Avec ce raisonnement je m'demande pourquoi ils ont pas encore mangé Canon, Nikon et Sony.
J'ai pas de voigtlander et pour le coup, j'me sens con. |
| Coignet |
paga a écrit : C'est parce que sur un Leica M on met une optique... Leica, tadaaa!Imagine que tu veuilles un télémétrique mécanique bien fait avec une cellule dedans : il n'y a que Leica ; imagine ensuite que tu n'aimes pas le 2/50 Leica et que le 1.4/50 soit trop cher pour toi : il y a d'autres marques (tadaa). Quant à cette histoire de Voigt' qui ouvre à f:1, à mon humble avis, c'est du pipo, une blague, un bruit de fond de net : nada. ma signature |
| reuno |
Spécialiste Messages : 1429Depuis le 14 août 2006 Nord |
fotd a écrit : Le marketing viral de Voigt est remarquable. Il nous annonce des produitsséduisants avec des mois d’avance. Distille des fuites (le coup du flikr c’est un peu gros). On bave. Et pendant ce temps, le prix augmente de 100$ chaque mois. Quand ce 50/1 sera en magasin, j’irai comme un lapin mécanique m’en acheter un, le cerveau lavé par ces longs mois d’attente. A comparer au Bessa MF 667. Les listes de précommande sont pleines et on n’en a toujours pas vu la queue d’un. Je dis bravo ! Mouais... en l'occurence les photos sur flickr sont de TOM A, membre de RFF qui a decidé de les mettre en ligne voyant que la rumeur avait gagnée le forum. Selon moi il n'y a pas vraiment de politique "marketing virale" chez VC... ou alors elle est vraiment excellente et ils m'en ont persuadés à mon insu. Je crois que les mecs de RFF outre atlantique se montent la tête pour rien parfois, et malheureusement ils influencent la tendance générale. http://www.renaud-coilliot.net SIGMA France |
| yanidel |
Régulier Messages : 264Depuis le 15 sep 2008 Rosario, Argentine |
reuno a écrit : flickr sont de TOM A, membre de RFF qui a decidé de les mettre en ligne voyant que la rumeur avait gagnée le forum. Selon moi il n'y a pas vraiment de politique "marketing virale" chez VC... ou alors elle est vraiment excellente et ils m'en ont persuadés à mon insu. Je crois que les mecs de RFF outre atlantique se montent la tête pour rien parfois, et malheureusement ils influencent la tendance générale.Pas mal de préjugés sur le RFF je vois ... la rumeur est venue d'Australie, puis du Japon, pour une fois les ricains n'ont rien fait ... Je pense aussi qu'il n'y a pas vraiment de "marketing virale" chez VC. Íls développent un produit, l'annoncent deux mois avant sa disponibilité et ont toujours des stocks importants dès la sortie. Leur site internet rivalise d'ailleurs en qualité avec celui de la mairie de Joussin-les-Mottes. |
| manukiev4 |
Je crois surtout que la politique de Voigtlander/Cosina est bien foutue par le fait que plusieurs revendeurs officiels de la marque à l'étranger sont sur le site RFF qui est dans le domaine du télémétrique une référence au niveau international du fait du nombre d'adhérents et de passionnés. De plus, ces mêmes revendeurs participent aux discussions sur de nombreux sujets qui montrent les attentes des consommateurs amoureux de ce type de matériel.
Si on regarde jusqu'à présent, ils ont toujours visé juste, avec du matériel de bonne qualité pour pas trop cher. Alors on peut toujours dire que ça n'a pas la qualité du Leica, mais il s'agit d'objets plutôt bien foutus qui font ce qu'on leur demande et qui répondent à ce qu'on attendait d'eux. Moi j'ai un M2 et un Bessa T et bien je suis content d'avoir les deux. J'aime mon Bessa qui m'a permis de rentrer dans le monde du télémétrique Leica pour moins de 200 euros neuf et je l'utilise toujours. Ca commence par : "Jak sie pan?"; et ça fini par : "Do dna".
| yanidel |
En fait, le RFF appartient à Stephen Gandy (avatar cameraquest) ... qui est le propriétaire du plus gros revendeur Cosina aux US : www.cameraquest.com
Cela explique probablement beaucoup de choses ... |
Utilisateurs parcourant cette section : Google [Bot] et 6 invités
